How big a bilge pump should be fitted to a boat? A question I attempted to answer by calculating how many gallons of water would flow through a 1" hole located 2' below the waterline. The answer is 30 gallons per minute or 1,800 gallons per hour (15,012 lb./hr).
My general conclusion: a bilge pump was good for dewatering the bilge and perhaps would "buy" a sailor a little time but unless the inflow of water is stopped, Davey Jones would be your neighbor.
Regardless, IDUNA is fitted with a Henderson Mark V hand operated bilge pump and will be fitted with a small electric pump for dewatering the boat. The other option available, is to fit a Sabb engine driven pump to the boat's Sabb G engine.
Happy New Year,
s/v IDUNA
