1.Union Diesel Parts Co.,Ltd is the diesel fuel injection Manufacturer, specialist in producing Diesel;VE Pump Parts;fuel pump;Repair kit;Pump Plunger;Nozzle;Delivery Valve;Hydraulic Head;Governor Cover;Pump Housing ;Drive Shaft;Spring;Magnet Valve;Control Shaft;Electric Governor;Control Valve;Roller Ring;Pencil nozzle;Cross Disc;Supply Pump;Cam Plate;Fulcrum Lever
2.Diesel fuel injection system component are our major produce. we are a constant partner to our customers,from the planning stage right through service.In short,We don’t just sell a product, We offer complete soluations.
3.many years experience in diesel fuel injection system making .
4.Hundreds of coustomers all over the world.
5.Thousands of kind components produce ability.
6.We will of course continue to do so in order to meet the increasingly complex requirements of our customers and find solution.
Dear Sir/Madam :
Have a nice day!
I am from Union Diesel Parts Co.,Ltd .Very glad introduce our company .
Our maijor parts is VE PUMP PARTS .
on the base of serial diesel injection parts,Also Our products have excellent
replacement performance in many kinds of reputable brand like
BOSCH, ZEXEL, DENSO, IVECO, ISUZU, MATSUBISHI, CAT, KATO, KOMATSU, CUMMINS and so on.
such as injection nozzles, pump elements, delivery valves, Head Rotor etc
manufacture new parts .LUCAS .7123-340U .7139-360U
7123-345U etc .Pencil nozzle 27333,27336,26632,26964 of stanadyne .HD90101A etc .
Of course,I will give you the excellent quality and
the very competitive price and complete after sale-serivce. .
no problem If you have supplier now, we can establish friendship with each other.
Then we can try my best to help you.
Hope of establish business relationship with you.
Attach products list
Looking forward to hearing from you soon
Thanks and best-regard!
http://www.undiesel.com
MSN: undiesel@hotmail.com
Email: undiesel@undiesel.com
oducing Diesel;VE Pump Parts;fuel pump;Repair kit;Pump Plunger;Nozzle;Delivery Valve;Hydraulic Head;Governor Cover;Pump Housing ;Drive Shaft;Spring;Magnet Valve;Control Shaft;Electric Governor;Control Valve;Roller Ring;Pencil nozzle;Cross Disc;Supply Pump;Cam Plate;Fulcrum L2.Diesel fuel injection system component are our major produce. we are a constant 12v fuel pump ac delco fuel pump ac fuel pump aeromotive fuel pump alero fuel pump alfa romeo ambac ambac international audi a4 fuel pump audi fuel pump auto diesel parts auto fuel pump automotive fuel pump barrel bedford bedford 500 BEDFORD KIT belts hoses BMC 1500 BMC 4/98 BMW bmw fuel pump bmw idle control valve bnc 1500 bosch bosch delivery valve bosch diesel fuel injection bosch diesel fuel injection pump bosch diesel fuel injection pumps bosch fuel injection pump bosch fuel pump bosch hydraulic head bosch idle control valve bosch injection bosch pump bosch ve diesel injection pump bosch ve diesel pump bosch ve fuel injection pump bosch ve fuel pump bosch ve injection pump bosch ve injector pump bosch ve pump bosch ve pump parts broken cross disc bryce Cam Disk cam disks Cam Plate Cam Plate cam plates camaro fuel pump camry fuel pump car fuel pump caravan fuel pump carter fuel pump carter fuel pumps case ih Cat Pencil Nozzle Cat Pencil Nozzle caterpillar cav fuel injection cavalier fuel pump CDC/PERKINS chem feed pump chevrolet fuel pump chevy truck fuel pump CHRYSLER cleaning fuel injection control arm shaft control arm shaft kit Control Cover control covers Control Shaft Control Valve control valve chrysler control valve india control valve manufacturer control valve manufacturers control valve parts control valve price control valve type controle valve controle valves controlled valves controls valves Cross Cube Cross Disc cross roller ring cube cross CUMMINS cummins 4bt cummins 6bt-5.9 cummins cam plate cummins cup cummins delivery valve cummins diesel cummins diesel fuel injection cummins engine parts cummins fuel injection cummins fuel pump cummins injector cummins injectors cummins system cummins ve pump CUMMINS:4BT CUMMINS:6BT-5.9 D.Valve dakota fuel pump DEL. Valve delco fuel pump Delivery Valve Delivery Valve delivery valves Delivery-Valve Assembly delkron cam plate delphi delphi fuel injection denso denso fuel injection denso fuel pump DEUTZ DEUTZ/KHD diesel bosch diesel delivery valve diesel elements diesel engine diesel engine fuel injection diesel engine injection diesel engine part diesel engine part diesel engine parts diesel engine parts diesel engine spare diesel engine spares diesel engines diesel feed pump diesel fuel diesel fuel cleaner diesel fuel cleaning diesel fuel distributor diesel fuel engine diesel fuel filter diesel fuel filters diesel fuel injection diesel fuel injection diesel fuel injection equipment diesel fuel injection equipment diesel fuel injection nozzle diesel fuel injection part diesel fuel injection part diesel fuel injection parts diesel fuel injection parts diesel fuel injection pressure diesel fuel injection problems diesel fuel injection pump diesel fuel injection pump diesel fuel injection pump parts diesel fuel injection pump test diesel fuel injection pump test bench diesel fuel injection pump test equipment diesel fuel injection pumps diesel fuel injection pumps diesel fuel injection repair diesel fuel injection service diesel fuel injection services diesel fuel injection specialists diesel fuel injection system diesel fuel injection system diesel fuel injection systems diesel fuel injection systems diesel fuel injection timing diesel fuel injections diesel fuel injector diesel fuel injector diesel fuel injectors diesel fuel injectors diesel fuel nozzle diesel fuel parts diesel fuel pump diesel fuel pumps diesel fuel system diesel fuel systems diesel fuel transfer pump diesel injection diesel injection diesel injection equipment diesel injection equipment diesel injection part diesel injection part diesel injection parts diesel injection parts diesel injection pump diesel injection pump diesel injection pumps diesel injection pumps diesel injection system diesel injection system diesel injection systems diesel injection systems diesel injector diesel injector diesel injectors diesel injectors diesel kiki diesel lucas diesel motor diesel nozzle diesel part diesel parts diesel plunger diesel pump diesel specialists diesel tester diesel truck diesel turbo diesel zexel dipaco disa disc cam disc cams dodge dakota fuel pump dodge fuel pump dodge neon fuel pump doowon double regulating valve Drive Shaft Drive Shaft driveshaft e30 fuel pump efi fuel pump Electric Governor electromagnetic valve element elements engine fuel injection Equipment f150 fuel pump fass fuel pump Feed Pump Feed Pump feed pump turbine feed pumps feeding pump feuling cam plate fiat/allison flo control valve FORD ford/nissan fuel bosch fuel engine fuel engines fuel feed pump fuel injection fuel injection fuel injection equipment fuel injection equipment fuel injection nozzle fuel injection part fuel injection part fuel injection parts fuel injection parts fuel injection pump fuel injection pump fuel injection pumps fuel injection pumps fuel injection system fuel injection system fuel injection systems fuel injection systems fuel injections fuel injector fuel injector fuel injector nozzle fuel injector pump fuel injectors fuel injectors fuel nozzle fuel pressure regulating valve fuel pump fuel pump fuel pump assembly fuel pump kit fuel pump parts fuel pump plunger fuel pump price fuel pump prices fuel pump problems fuel pump repair fuel supply pump fuel valve Fulcrum Lever garrett Gasket GM gm fuel injection gm fuel pump gmc fuel pump gmc jimmy fuel pump Governor Governor adjusting Governor Cover harley cam plate hartridge head pump Head Rotor Head Rotor Lucas Head Rotor Lucas Head Rotor Nozzle Head Rotor Nozzle head turbine holley fuel pump holset HONDA honda civic fuel pump honda fuel pump honda idle control valve honda pump honeywell pressure regulating valve how diesel fuel injection Hydraulic Head hydraulic head loss hydraulic head pressure hydraulic heads hydraulics head iceco-8140 idle control valve problems in control cover injection engine injection nozzle injection parts injection pump injector injector nozzle injector pump injector pumps injector valve injectors pumps integra fuel pump interchangeable interstate mcbee ISUZU ISUZU 4JB1 ISUZU 4JB1T ISUZU PK IVECO IVECO 40-10 IVECO 40-8 IVECO 49-12 IVECO/RENAULT IVECO-8060 IVECO-8140 jeep cherokee fuel pump jeep fuel pump jeep wrangler fuel pump jetta fuel pump john John Deere KOMATSU LAND ROVER 2.25 LEYLAND 680 lucas lucas diesel fuel injection lucas fuel injection lucas no lutong m35a2 M35A2 truck m60 Magnet Valve Magnet Valve magnet valves magnetic valve magnetic valves malibu fuel pump marine diesel fuel injection marine fuel injection masoneilan control valve maxima fuel pump MAZDA mazda fuel pump mercedes diesel mercedes diesel fuel injection mercedes fuel pump mico mikuni fuel pump military truck military trucks military vehicles MITSUBISHI mitsubishi 4d55 model 100 motorpal MWM D225/6 neon fuel pump nippen denso NISSAN nissan cd17 nissan fuel pump nissan td27 nissan td42 Nozzle nozzle engine nozzle holder nozzle manufacturer nozzle manufacturers nozzle size nozzle sizes Nozzle Tip nozzle tips nozzle types nozzles nozzles tips offset control arm shaft oil feed pump omap other no panasonic roller ring passat fuel pump Pencil nozzle perkins 3 cyl perkins 4 cyl PERKINS 6 CYL. PERKINS 6354 perkins t6354 pierburg fuel pump Plunger Plunger plunger barrel plunger oil pump plunger pump plunger pumps plunger type pump plunger valve plunger valves plungers powerstroke fuel pump pressure regulating valve pressure regulator valve pump pump assembly pump control valve pump fuel Pump Housing pump hydraulic head pump injection pump injectors pump nozzle Pump Plunger pump rotor pump valve Regulating Valve regulating valve india regulating valves renault Repair Kit roller assy roller ball bearing roller bearing roller bearings roller racing Roller Ring roller rings roller shaft rotor turbine s10 fuel pump saab fuel pump samsung shaft drives silverado fuel pump snowmobile fuel pump spaco Speed Control Spring spring plunger stanadyne su fuel pump subaru fuel pump supplier pump Supply Pump supply pumps tahoe fuel pump tdi fuel injection tdi fuel injectors tdi fuel pump testing fuel injection TOYOTA TOYOTA 14B toyota ihz Triplex coupling triplex plunger pump turbine nozzle turbo diesel fuel injection turbo fuel injection turbo nozzle turbocharge unit fuel injection upper control arm shaft us5 in control cover valve valve pump valve system valve systems ve diesel injection pump ve diesel injector pump ve diesel pump ve fuel injection pump ve fuel pump ve injection pump ve injector pump ve pump Ve Pump ve pump kit VE Pump Parts ve pumps vehicle model VOLVO volvo penta walbro 255 fuel pump walbro fuel pump walbro fuel pumps watts regulating valve weldon fuel pump wilkins pressure regulating valve wrx fuel pump yanmar yanmar fuel injection yanmar fuel injector zexel ZEXEL NO zexel ve pump
AEC505 AIDO(CN) ALFA ROMEO ALLISON AUDI AVL BARRIEOUS D26 BARRIEOUS D36 BEDFORD BEDFORD 500 BEDFORD KIT BENC BENFRA BINGCHAI BMC BMC 1500 BMC 4/98 CA4DF2 CA6110/125 CA6DF1-28 CA6DF2D-21 CARTR CASE IH CDC CHANGCHAI CHANGCHUN40 495A CHANGJIANG CHAOCHAI CHAOCHAI4102 CHAOCHAI6102 CHAOCHAI6102(6BD1) CHAOCHAI6102BZQ CHII CIEFANG COASTER CUMMINS CUMMINS 6BT5.9 CUMMINS/EXPORT CUMMINS:4BT DACHAI DACHAI 6DE DACHAI6110 DACHAI6113 DACHAICA498 DAEWOO DAEWOO/EXPORT DAF DAFA DAIHATSU DALIAN DALIAN DIESEL MANUFACTURER DALIAN DIESEL/EXPORT DEUTZ DEUTZ/EXPORT DOMATSU DONFENG DONGFANGHONG DONGFENG6 CAT210 DONGFENG6 CAT240 DONGQI SAW DORMAN ENGINEELING EQ\153 EXPORT EXPORT0 FIAT FORD FORD TCTOR 3CYL FORD TRACTOR 3CYL. FUJIHEAVY GOANGXILIUFA GOLDEN H06C/H06CTA H07C/H07C-A HAEP HANGFA HANOMAG HECHAIBR-TD234 HINO HINO Isuzu HINO/BOSCH HINO/EXPORT HKR HUDONG6105 HYUMDAI IHC 4CYL IMITSUBISHI INTERCHANGEABLE: INTERCHANGEACE: INTERNAT IONAL ISEKI ISEKIISUZU ISHIKAWAJIMAS ISHI-SHIBA ISUZU ISUZU 4FB1T ISUZU 4FCI ISUZU 4JB1 ISUZU 4JB1T ISUZU 4JB2 ISUZU PK ISUZU/BOSCH ISUZU/EXPORT IVECO IVECO 40-10 IVECO 40-8 IVECO 49-10 IVECO 49-12 IVECO/35-10T IVECO/8140-27 IVECO/VE R 573 IVECO40-10T IVECO49-10T IVECO-8060 IVECO-8140 JICHAI Z12V-190B JMC JMCTFR4JB1-NA JOHN DEERE KHD KINGLONG/EXPORT KOMATAU KOMATSU KOMATSU/EXPORT KUBOTA LAIDONG LAIDONG480 485 495 LAND ROVER 2.25 LEYLAND LEYLAND 680 LIUFA6105 LUOYANG TRACTOR 105 M.BISHIHI.NAG MACK 676 MADE INJAPAN MAN MAN\D2865 MAZDA MAZDA/EXPORT MAZDA:PN54 MISSAN DIESEL Mit/EXPORT MITSUBISHI MITSUBISHI 4D55 MITSUBISHI HEAV MITSUBISHI/EXPORT MITSUBISHINM12 MWM D225/6 NANCHONG DIESEL MANUFACTURER NANJING NAVISTAR DTA-466 NFD150 NHR NHR\NKR NIIGATA URAWA/NIIGATA TEKKOU NISSAN NISSAN AD23 NISSAN AD27 NISSAN CD17 NISSAN D20-T NISSAN DIESEL NISSAN DIESEL/BOSCH NISSAN DIESEL/EXPORT NISSAN DIESELISHIKAWAJIMAS NISSAN TD42 NISSAN/EXPORT NISSAN-D NISSANTD27 OPEL PERK PERK 3CYL PERK 4236 PERK 4248 PERK/MF 3CYL PERKINS PERKINS 3CYL PERKINS 4CYL PERKINS 6354 PERKINS 6CYL PERKINS T6354 PERKINS/MF 3 CYL RBTR RENAULT RIAZ RUSSIAN TRACTORS SAMSUNG SAW SDEF SEAT SF498G SHANFCHAI SHANGCHAI/186/WF SHANGCHAID6114 SHANGCHAIG6135 SHANGHAI SHANOS STEYR STEYRWD615 X6130Q TATRA TFR4JB1T TIENTSIN TOYO-SHA TOYOTA TOYOTA 14B TOYOTA 1HZ TOYOTA/EXPORT TS230 USE HR04 USE HR11 USE HR45 VMW VMW-X VOLVO VOLVO PENTA VOVLO ENGINE VW VW(CK) VW(ME) VW(ME)/VE R 270 WD615 WD615.46HANGFA WD615.67 WD615.68 WEICHAI WUXI XICHAI XICHAI4110 XICHAI6110 XICHAI6110(6D14) XICHAI6110A XICHAICA6110 XIEFANG XINGCHAI YAMAHA YAN’AN YANGCHAI YANGCHAI4102QI YANMAR YANMAR/EXPORT YC YC4110Q YC4110ZLQ YC6112 YC6112ZLQ YELLOW RIVER YUCHAI YUCHAI4110Q YUCHAI6105QC YUCHAI6108 YUCHAI6112 YUCHAI61DB ZB400KUBOTA
20494 23836 26632 26964 27333 27836 28481 28485 29279 32262 33408 800001 800320 800717 800858 800859 0 330 001 015 0 433 171 214 0 433 175 031 0 434 250 072 0 434 250 103 0 434 250 128 0 434 250 176 0 434 250 898 0 460 484 006 093400-1330 093400-5320 093400-6190 096140-0030 096400-0143 096400-1250 096400-1330 1 418 325 096 1 467 010 059 1 468 334 327 1 468 334 946 105000-1130 105007-1120 105015-3280 113 VW 131151-3220 134101-6420 146405-1920 146600-1120 2 418 425 988 2 418 425 989 2 418 450 011 2 418 455 122 2 418 455 129 2 418 455 165 2 418 455 580 2 468 335 022 2 468 336 013 4W7016 7123/340U 8N7005 BDL30S46 DLLA144P184 DLLA146P197 DLLA150P24 DLLA150P43 DLLA150P52 DLLA150P59 DLLA150P602 DLLA150P77 DLLA150P9 DLLA152P452 DLLA155P230 DLLA155PN118 DLLA158P7154 DN0PDN112 DN0PDN113 DN0SD1510 DN0SD1930 DN0SD211 DN0SD2110 DN0SD220 DN0SD240 DN0SD261 DN0SD265 DN0SD273 DN0SD274 DN0SD293 DN0SD294 DN0SD297 DN0SD299 DN0SD301 DN0SD302 DN0SD304 DN0SD308 DN0SD314 DN10PDN130 DN12SD12 DN12SD290 dn12sn12 DN15PD609 DN20PD32 DN4PD1 DN4PD57 DN4S1 DN4SD24 DN4SDND133 dnosd193 dnosd261 dnosd265 dnosd293 dnosd297 DSLA145P208 DSLA145P366 DSLA150P357 DSLA150P442 DSLA150P502 DSLA150P520 hd90100 HD90101A PN PS7100 PS8500
