Hi Tom,
First, I don’t understand why you are tying them against the mast while
underway. The major advantage to the lazy jacks is that they support the
boom and the sails while reefing or dropping the sails. If the lazy jacks
are too taut to effect the sail shape, then loosen them at the cleat. I
only put the lazy jacks against the mast when I put up an awning. However,
it you are certain you want your lazy jacks against the mast while underway,
I think you should consider the following:
There are several possibilities causing your problem. The first thing I
suspect is the stainless steel thimbles are too large. For 1/4-inch nylon
three strand, I use 3/16-inch thimbles. This lets some nylon material
overlap slightly so the stainless does not contact the mast. Another
possible problem is the lazy jack are not pulled down tight enough if they
are chafing the mast. . If this is still a concern, consider nylon
thimbles instead of stainless. However, they will have to be replaced about
once a year because the rope will chafe through the bottom of the thimble.
If you use an eye splice you will find the lazy jacks are more difficult to
adjust and will soon chafe through the bottom of the spliced eye.
I hope this helps some Tom, if not let me know and I will try to explain
further.
For those of you that are having problems getting your sail head caught
under the lazy jacks while raising, I suggest you consider moving the top of
the lazy jacks to the intermediate shrouds. I tie mine down about 18-inches
from the mast tang. I attach the lazy jacks to the shroud with a double
rolling hitch then continue up to the mast tang to terminate the line. This
prevents the line from slipping down the shroud. If you want to test this
idea, just untie the lazy jacks at the mast and move them outside the
intermediate shroud to see how it works. Do not leave them in this position
too long because the line will chafe through where it passes over the
shroud.
Since I am rambling, I really like to use my lazy jacks as the topping lift.
To do this, I adjust the lazy jacks so the boom lifts above the boomgallows
when the sails are furled on the boom. To pull the boom into the gallows, I
use the main sheet. When the mainsheet is released, the boom should
immediately lift above the gallows. After the sails are up, the boom will
lift further, leaving some slack in the lazy jacks. If they are still too
taut so they interfere with the shape of the sail or while on a run, loosen
the lazy jack on the lee side.
If the lazy jacks are properly made and installed they can be easily moved
to the mast to put on the main sail cover or a sun awning. To do this, the
aftermost clip can be released from the short pigtail. Then all the lazy
jacks (one side at a time) can be moved forward to the mast. Here, attach
the clip to the highest thimble that can be reached. Then pull down on all
the lazy jacks equally. The nylon will stretch so they can be pulled down
taut to a cleat. The location of this cleat will determine the tautness of
the lazy jacks. Normally, existing whisker pole topping lifts, etc can be
used. To reinstall, just unclip from the thimble and walk the clip back to
the aft pig tail and you are back in business.
Sorry, didn’t mean to ramble on so but I am so happy with my lazy jacks and
the way they work I hate to thinks others out there could be unhappy with
theirs.
Roger
To: <bcc@yahoogroups.com >
Sent: Friday, January 10, 2003 7:34 AM
Subject: [bcc] Lazy Jack chafe
If you are using Roger’s lazy jack system, you might want to
check your spars for chafe. I had been tying mine off at the goose neck
when underway and discovered that the thimbles have chafed off all the
awlgrip and have started to work on the spar…this after 4 months of
use. I am changing to using spliced eyes only…
PS: has anyone calculated the correct gross tonnage for our boats?
Tom Harrer
S/V Whitewings III
