Leading reef lines back to the cockpit.
Apparently, I am bored so I made up another information sheet on how to lead the reef lines back to the cockpit. Many of you already have this installed or may prefer to go to the mast. I provide it just in case there are those out there who would like to know. Part of this is taken from my book but this explains the details of installing it on a BCC.
Roger Olson
http://www.samlmorse.com/nereus/cockpit_reefing.pdf
Roger, I am thoroughly enjoying picking your brains firstly from your book and secendly by the good grace of your steady stream of info you have so freely donated to the forum. Long may your boredom continue. As you may be aware I am presently finishing hull 126 and the input is not only timely but also of great use at this stage of construction. Keep up the good work.
