Lee helm
OK … over at http://boatdesign.net I got a hit I was looking for
"The CoE/CLR relationship with regards to weather helm is in my opinion grossly overstated. Obviously the couple between these two centroids will produce a turning moment, but counter intuitive as it may seem, this doesn’t always translate to alterations in the feel of the helm.
I have seen some hulls continue to have weather helm despite everything being done, including the adding of bowsprits and the addition of skegs. I have also raced boats where there is absolutely no change in either the feel of the helm or the yacht’s maneuverability when either the mainsail or alternatively the genoa, is dropped. Ridding a boat of all the ‘effort’ from one side of the CLR, in theory should lead to an immediate and significant change to the helm. But you stand on the Green at Cowes Week and watch how many classes jig around right up to the 5 minute gun with just their mainsails raised. They all happily tack, bear away, and go up and down wind without a loss of control, but their ‘centroids’ must be showing enormous theoretical imbalance.
About 15 years ago we were paid to investigate the ‘balance’ of a proposed new super yacht with the construction of a large free sailing model. All the ballasting was done internally so the CoG remained constant while the keel position was varied over nearly 20% of it LWL. No changes in the helm were detected.
The oft quoted relationship between the centroids allows designers to produce boats of normal form. There is therefore every expectation that these boats will steer and balance within acceptable ‘norms’. But it doesn’t follow that such a relationship incorporates all the variables.
My first advice is to make sure the bottom of your boat and rudder are absolutely clean".
Crag Cay.
You can take a look at the discussion there at Problem with lee helm | Boat Design Net
Well my bottom was filthy the other day when I was sailing up for my haulout. Although I seem to remember that I had lee helm on other occasions with a clean bottom. But the mind can me a wonderful thing, especially after all the years of rum.
So, I will take out the yankee and sail with both the yankee and the new jib. this of course after I finish the haul out. I will even try towing the dinghy from different quarters.
Ok – I can verify this theory as well. It’s been blowing 25kts+ the last few days, so I’ve just been running a fores’l and stays’l – CoE has got to be forward of the centerboard – and low and behold, I still experience slight weather helm at least when gusting. So, who knows weather helm and The CoE/CLR relationship might be unrelated after all…
A pic of Valora under fore and stay only:
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs227.snc4/38700_115333818518649_100001260933829_104854_4183162_n.jpg
Boat designer build in CE lead in relationship to the CLR to counteract turning moment caused by the CE being outside the center line of the boat when the boat is heeled. Suggest you read Helm Balance, p92 in Ted Brewer’s book Understanding Boat Design.
If a boat has too much lead, it will have lee helm. The amount of CE lead in relationship to the CLR is very much dependent on the boat design and the experience of the designer. As a boat heels the CE moves outside the boat causing it to turn into the wind. As an example, with one finger on the point of a pencil hold the pencil vertical with the eraser on a flat surface. Assume the lettering is forward. Move the tip of the pencil forward. If this were a mast, the bow would dig into the water - downwind spinnaker runs. Now heel the pencil and ensure the eraser end can not slide on the surface with your free hand. Now push the pencil forward at the tip. The pencil tip will move in a circle toward the weather side of the boat. This assumes the pencil is directly above the CLR. To counter this turning moment, designers build in lead (lee helm) by place the CE forward of the CLR. Normally, This would cause lee helm. By placing the CE forward of the CLR, the boat has neutral helm until the heel angle increases to the point where induced lee helm caused by the lead can no longer counter the turning moment caused by the centered CE being outside the boat. If boat does not have enough lead, it will develop weather helm early and if it has too much lead, it will develop lee helm.
In the late 40’s and early 50’s, one yacht designer, designed custom cruising boats with two centerboard keels - one aft and one forward the CE. By raising and lowering the boards, one could move the CLR in relationship to the CE, thus balancing the boat in all wind conditions and angles of heel.
This is all I will write about the subject. This subject is covered extensively in Brewer’s book and Greene’s book Cruising Sailboat Kinetics.
BCC IDUNA
I think your sail plan image might provide the answer.
The CoE of the new jib is lower, and the foot of the new sail is considerably lower, therefore, the CoE on the new sail seems to be forward and lower.
A line drawn between the clew and the midpoint on the forestay will indicate the CoE.
In a wind, and assuming a 15 degree list, the jib will “throw away” effort from the top of the sail, so the lower the foot, the more power the jib will retain.
The attached image is extremely rough,I didn’t take exact measurements,
Thanks John, what you say is the direction I am leaning. But it does seem like a lot of change for the difference in CoE. The compariosn sail will tell the tail.
Thanks Rod,
I think what may be happening is the new sail has moved the CoE to far forward, as John mentioned. I must have reached a breaking point between lee and weather helm. the result was way to obvious. My first thoughts were the obvious, which was the trim point. But that seems to be only a by product of the new sail and not the cause.
I will purchase the books you recommened.
Great thread and discussion! I may be on the verge of discovering why my boat moves.
“Terrier” #31
Tom:
Boat are propelled by “The Force” and we only hoist sail to look good :slight_smile:
On Fri, Aug 6, 2010 at 6:25 PM, BCC Forums bccforums@samlmorse.com wrote:
