John,
I have to echo the comments of Debbie Smith.
Decks - I see no advantage to teak decks. Yes, they add a nice touch but
the maintenance and expense far outweigh the appearance.
Cockpit - Close, but no problems (I have to compare it to a Catalina 30,
the only other boat I have owned). We set up small cushions that lace to
each of the gallows stanchions and the person “on watch” usually sits to
the leeward and leans against that cushion. The wind vane, jibsheet and
mainsheet are right at hand. (OK, you do have to get up to reach the
staysail sheet - 3 out of 4 ain’t bad!) 4 adults in the cockpit when
anchored or coastal cruising isn’t a problem either.
Bowsprit strength - If you look at how the sprit is rigged, most of the
loads are taken by the bobstay, whisker stays, and forestay/backstay. - and
they are plenty strong! The other significant load is compression on the
bowsprit itself, the easiest for it to withstand. Bottom line - no sweat!!
But, to answer your other question, I think there is a type of pulpit that
fits onto the end of the sprit, but it doesn’t have the “gangplank” like
the Wetsnail.
Space for family - Like Debbie, we too have cruised with “full-size” adults
(4 in our case) on longer trips - 300 miles and 600+ miles, and we are
still close friends. It does require accommodation, some of which would
not be required within a family group. As I mentioned above, I used to
have a Catalina 30 (nick-named both “Moby-Cat” and “Jonah” - is there a
clue in there!!!), and no, there isn’t that kind of space below.
Double space - For implied activities, it is close, but it works. And no,
I don’t think it will end the marriage. We made a cockpit bed, and on hot,
stuff nights, that solves heat and ventilation problems also.
Pilot Berth - I’ve slept in it and at 5’10 and 175#, I don’t have any problems
(other than getting out in a hurry when that boat dragged down on us!) A small
fan at the head of the berth helps in hot weather.
Crealock 34 comparison - Let me preface this response by saying I’ve never been
on a Crealock 34 - but I do have a data point. The first owner of our BCC (#95)
now has one, and he has said several times that he wished he had not sold the
BCC. His family expanded to 4 and he felt he needed more room. He says that he
has a little more elbow room, but in his opinion, not really enough to justify
the extra expense. He has had some mechanical problems with the boat. However,
it is important to mention that he is not the first owner and there is a good
chance that the problems he is experiencing are traceable to the first owner.
Hope I’ve added a few answers. Good luck
Tom Walker
Aloha
BCC #95
______________________________ Reply Separator _________________________________
Subject: [bcc] Opinions from Owners
Author: jkane@uoft02.utoledo.edu at SMTPGATE
Date: 1/20/99 17:37
I have enjoyed the recent flurry of questions and answers coming from all of
you experienced owners. So, I came up with some myself. 1. If buying new,
would you specify wooden decks? Why or why not? 2. Is the BCC flush deck
cockpit enjoyable enough for cruising, it looks exhausting? Are the cockpit
combing boards high enough and comfortable enough for leaning back on?
3. The bowsprit looks too flimsey to walk out on, has anyone added a pullpit
on the bowsprit like a Westsail 32? Does it make sense, or just detract from
the beauty. 4. I have a family of five. Is the BCC big enough (I have
only seen pictures) to accomodate five for limited cruising and weekend
excursions. 5. Is the “double berth” big enough for a married couple, or
will that end the marriage? 6. I have thought about port and starboard
quarter berths with the sink and range across from each other like on the
Falmouth Cutter, but with a pilot berth and two seatee berths. Would this
work out? Has anyone tried it? 7. Used as a pilot berth, is the pilot
berth big enough for a slim, 5’9" teenager to sleep on? 8. As the Sam Morse
Home Page obviously compares the BCC to a Crealock 34 for a size comparison,
if you were to buy new, would you buy the Crealock 34 or the BCC 28? So many
questions come to mind. Thank you all for your answers. John
HOW LOW CAN YOU GO? How does a 2.9% intro APR Visa sound?
Transfer your balances from other high rate credit cards and save!
Learn more at: http://offers.egroups.com/click/204/1
Free Web-based e-mail groups by eGroups.com
