Tom:
I thought about the problem and came up with a similar solution to yours. I would install bent naval brass guards at the corners between the eyebrow and the corner of the cabin sides. These could easily be made from 1/2" X 1/8" flat stock - www.mcmaster.com . One could either cold bend these in a vice or heat them with a propane torch then bend them. Naval brass was (is) used in propeller shafting. I believe it is also referred to as Tolbin Bronze and Naval Bronze.
P.S. There is always a project in the works - 7’8" Two Paw nesting pram (www.BandByachdesigns.com) after installing the deadwood and keel. The boat will weigh less than 50 lb. upon completion.
Attachment: DSC02234SM.jpg 52(kb)
