RE. Jibs and Winches
Hello John, I have the same Barients on Pelagic #93. You are correct
about the single screw. Just remove it and pull the drum straight up.
If it is sticky you might want to wack the underside of the upper lip
with a soft mallet. There is nothing else holding it. There are two
nylon or delrin bearing sets. They may need cleaning lubing or
replacing.
On the jib. Stick with the yankee. We love it for its power and
our ability to see under it. The standard sail plan is all that is
necessary to get all the performance and safety out of the boat. You
won’t regret it.
Good Luck,
Russ
