Removing Main Hatch Cover
Hi all,
Hate to ask dumb questions - but…
is there a trick to removing the main hatch cover from underneath the turtle?
thanks,
Ben
Ben:
Remove the seahood (turtle) then unscrew the slide rails on each side of the coaming. You will need to move the hatch forward and aft to remove all the screws in the slide rail. This assumes you have a metal rail mounted on the hatch coaming.
Ahh, so there is no trick to it – going to require removing the turtle… oh well, had hopes there was a simple solution. Removal of the seahood looks like it’ll be a few screws and some bedding compound at the very least.
thanks Rod!
