I took a scale to work today. The hollow spruce mast with radar antenna, mounting bracket,internal wiring, spreader lights and steaming light weighs 270 lbs; the boom with end fittings, 65 lbs and the gaff with saddle, 35 lbs. The four mast bands,spreaders and standing rigging (Dyneema) weigh 95 lbs. So total weight of spars and standing rigging is 465 lbs. I would like to know how that compares with the standard Forespar aluminum rig? Heavier I’m sure, but by 50 lbs or 250?
Ahoy David , Although I am not able to provide the total weights of a Forespar mast, for your comparisons, I am able to provide the extruded aluminum weight per meter.
I had a mast extruded here in Singapore and the extrusion section drawing is attached below.
The engineering drawing calculates a one meter section weight of 5.734 Kg per meter.
There are many other parts and fasteners to calculate as well .
Based on that I think my rig will be about 30 per cent heavier. My vertical center of gravity is lower with the shorter mast so maybe that will offset the effects of the heavier rig.
