Weather routing
A big shout out to Jeremy and Nica on Calypso. He has developed a weather routing website that is most useful! Using it now to make the jump between the BVI and St Martin. Go check it out at www.fastseas.com
Most interesting. Inquiring minds ask:
What polars and comfort criteria do you use, Gary?
For what sailplan (or sailplans) are your polars relevant?
Who created your polars: did you calculate them yourself from performance? or from a numeric model of the BCC and its sailplan? Or do Jeremy and Nica have a standard BCC polar?
On Z, I had mild success creating a table of target speeds and a polar using both performance data and working through a publicly available spreadsheet. The result was a fairly coarse (i.e. not fine detail) polar which I have used with QTVLM (a publicly available program for wind routing using GRIBs).
I lost my enthusiasm for the project a few years back (and am not certain I can find the polar now - that’s partly also because PCs and harddisks die without adequate backup!).
We usually sail Z in cutter configuration. In light winds and flat water, we fly an overlapping genoa without the staysail. Different performance (but that also might be a product of the state of the staysail, the sailcloth of which seems to age faster than that of the main or jib top - perhaps because of the way it gets handled).
