Just noticed this pulley wiggles. I cant recall if this is a new “feature” or not. According to my inexperienced self, it shouldn’t be wiggling and indicates the bearings are shot. Thought I’d throw it out here for confirmation. I made a quick vid of the offending wiggle which you can see here:
http://bccelizabeth.com/wiggle.mov
That is the bearing that failed on my engine. I had been hearing an intermittant chirping sound when suddenly the bearing locked up and sheared the shaft to the pump. I had to replace the water pump. I’m not sure about the “wiggle” but that bearing can be a problem.
Ron Thompson
Ho’okahiko 97
The bearing appears to be worn. You should replace before going to sea.
Rod, good to hear the confirmation, thanks.
Planning to order one up Tuesday.
