that is a lot different than mine, which is set at 11" pitch. do we
have different gearboxes perhaps?
john churchill
— In bcc@yahoogroups.com , “Sumio Oya” <info@s…> wrote:
Hi Mark,
The BCC #117 (Jill White & Tom Unrh) has studied performance and
send us
following message in last year.“looked up the settings for our Max-prop. PYI’s initial
recommendation of
22 degrees was way too steep, and we ended up at 16 degrees, or 8.6
inches
of pitch. The actual letter settings are x=C, y=K. This gave us
3600 rpm
with a clean bottom. We got a 300 rpm increase for each 2 degree
change.”Max prop Item # 63-316,
16" 3 blades,
16 degrees,
8.6 inches of pitch,
x = C
y = KI hope it will help your prop setting
Best Regards,
Sumio Oya
Sam L. Morse Co.
To: <bcc@yahoogroups.com >
Sent: Tuesday, January 14, 2003 7:44 AM
Subject: Re: [bcc] Re: feathering prop, shmethering propJohn,
I am curious if you know the setting for pitch for your
Maxprop. I havethe same 3GM27 and 3 blade Maxprop. I seem to get hull speed at
about
2400RPM . I understand that perhaps hull speed should be achieved at
clsoer
tofull RPM of about 3000 RPM.
The prop gererallly works great and have had no problems as long
as I keepit clean.
I am in the Hudson River and in July and August I need to don
the mask tokeep it clean as the river water warms causing an accumulation of
slime
andthen barnacles can grow with surprising speed.
Regards
Mark
SV Itchen # 73
Sent: Tuesday, January 14, 2003 10:30 AM
Subject: [bcc] Re: feathering prop, shmethering prop— In bcc@yahoogroups.com , “pelenur <pelenur@y…>”
<pelenur@y…>wrote:
I am still looking for a good feathering prop for my BCC. I
have atrusty 28 HP Volvo Penta ‘2003’ (made on 1988). My little
fixed 2blade prop does reasonably OK in forward…I am looking to
upgrademotoring speed (around 4.5-5 knots currently) and reduce fuel
useand sailing drag.
Does any one here actually use a 3 blade PYI Max-Prop? That
is mytop choice right now…
Does anyone think that there is no useful reduction in drag
from afixed 2 blade to a feathering 3 blade?
Julian
BCC #86 “Patience”
You should be getting more than that out of your 28 HP engine
if theprop is right, I would think. I suspect you may be
underpitched. Doyou easily reach full RPM? I had a fixed 3 blade, switched to
a 3blade MaxProp. No regrets. Do a search on this board
for “maxprop”;lots of info available. Do not know about difference in drag
betweena 2 blade. If it can be aligned with the “deadwood”, drag
should bedecreased, but I suspect most people would find it too much
bother todo so routinely.
John ChurchillBRISTOL CHANNEL CUTTER OWNERS ASSOCIATION
List owner: mailto:bcc-owner@yahoogroups.comYour use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/BRISTOL CHANNEL CUTTER OWNERS ASSOCIATION
