A question for those of you running Max Props
What is the length of shaft showing between your Prop and the Cutlass?
Not worried about tip clearance, more worried about proximity to rudder.
I have searched for info and pics with no joy
Keen to hear your ideas before I cut into my shaft
Might be good to make at least as long as you can fit a lead anode around the shaft. I have an anode at the end of the max prop which is great but only lasts about three months. The split ring that screws around the shaft might be a useful help, also depending on where you sail sometime a line cutter might be useful. In Maine the lobster pots were like a carpet. Snag a line and the damage might be up the line and create some big problems.
