MAST
Total height of mast 44’ 09"
Height to center of halyard sheaves 43" 09"
Height of mast from base to headstay eye 44’ 02 1/2"
Height to backstay hole (center) 44’ 08"
Height to upper shroud hole (center) 43’ 02"
Height to upper spreaders 32’ 01"
Height to staysail stay tang hole (center) 31’ 09"
Height to intermediate shroud hole (center) 31’ 10"
Height to lower spreaders 20’ 11"
Height to lower shroud hole (center) 20’ 08"
- Height to bottom of tri-sail track 7’ 03"
- Height to top of tri-sail track 30’ 00"
- Height to bottom of downwind pole track 9’ 09"
- Height to top of downwind pole track 24’ 00"
- Height to pole car lift (center) 24’ 03"
- Height to pole topping lift tang hole (cntr) 29’ 08"
 Height to center of goose neck 9’ 10"
- Cleats for pole topping lift 2
- Reefing cleats down haul under goose neck 2 or 3
- Mast steps at approx. 18" 19
 Length of backstay and headstay clevis (cntr) 3"
 Length of upper shroud plates (center) 3 1/2"
 Length of intermediate shroud plates (center) 3 1/2"
 Length of staysail clevis and plates (center) 4.75" + 1.5"
 Length of lower shroud plates (center) 5 3/4"
 Length of chainplates clevises (center) 3"
 All clevis pins and cotter pins provided 20
- Whisker pole size and type 3" X 14’
 BOOM
 Length of boom 15’ 09"
 STANDING RIGGING (center eye to 2/3 open) 316
 Headstay 9/32 - 1X19 40’ 2 3/4"
 Backstay 9/32 - 1X19 42’ 5"
 Staysail stay 9/32 - 1X19 26’ 6"
 Upper shroud, port & stbd. 1/4 - 1X19 37’ 9"
 Intermediate shroud, port & stbd 1/4 - 1X19 26’ 7 1/2"
 Lower fwd, port & stbd. 1/4 - 1X19 15’ 4"
 Lower aft, port & stbd. 1/4 - 1X19 15’ 8 1/2"
 Bob stay 3/8 - 1X19 8’ 00 1/2"
 Whisker stay port & stbd. 1/4 - 1X19 14’ 00 1/2"
 Boomkin stay, 5/16 - 1X19 3’ 10"
 SAILS (measured from end to end)
 Mainsail luff 32’ 06"
 Mainsail leach 34’ 06"
 Mainsail foot 14’ 08"
- Jib top luff 38’ 00"
- Jib top leach 30’ 09"
- Jib top foot 19’ 00"
 Yankee luff 38’ 00"
 Yankee leach 28’ 00"
 Yankee foot 16’ 00"
 Yankee pennant 10"
 Staysail luff 24’ 00"
 Staysail leach 21’ 06"
 Staysail foot 9’ 10"
 Staysail pennant 10"
- Reacher luff 36’ 10"
- Reacher leach 34’ 00"
- Reacher foot 24’ 02"
- Reacher pennant 10"
- Storm jib luff 21’ 03"
- Storm jib leach 16’ 00"
- Storm jib foot 9’ 01"
- Storm jib pennant 15"
- Tri-sail luff 14’ 06"
- Tri-sail leach 19’ 00"
- Tri-sail foot 11’ 06"
 RUNNING RIGGING
 Main halyard with snap shackle 75’
 Jib top halyard with snap shackle 78’
 Staysail halyard with snap shackle 50’
- Reacher halyard with snap shackle 75’
 Main sheet 96’
- Jib top sheet 90’
 Yankee sheet 84’
 Staysail sheet 60’
- Reacher sheet 115’
- Storm jib sheet 45’
- Tri-sail sheet 50’
- First Reef line, Outhaul 40’
- Second Reef Line, Outhaul 60’
- Third Reel Line, Outhaut 80’
- Reef Luff Down haul 20’
 Sheet blocks installed 5
 Two singles and one double block provided 3
 Bulwark sheet block slides provided 2
