We are still shopping around and looking at boats at various yards checking quality and processes being used before we commit Shamrock to the gelcoat peeler. Equally distressing is the letter from Roger Olson received 4 years ago but dated, believe it or not, "May 30, 2005 2:05 PM" looks like Rogers computer clock was a little screwed up; for that matter so was his account of the history of Shamrock. Back then Sam Morse had Crystalliner add a second coat of gelcoat to the bottom and the trapped resin did not cure; it also appear the original owner John Perbaugh, the first buyer, asked for additional gelcoat, so does this make 3 coats? Roger goes on to suggest, not sure because it was before his watch, the gelcoat may have been stripped and a barrier coat may have been applied. In short, this throws all the estimates we have out the window... I looks like we will have to haul and cut a window to make an acessment of the situation and go from there. I took a look at some boats being gelcoat peeled only, no deep peeling including glass layers, Smith saturation epoxy, epoxy fared and 4 coats of barrier coat, at Napa Valley Marina today. They did a 40+ power boat with speed rails molded in, nice work, good faring job. They also had a 50' catamaran gelcoat peeled and same process in the works, looks to be more of a fare job than I'm seeing elsewhere. Only down side seems to be the long trek north up the Napa River every year to haul and verify integrity of work and repair any new blisters if found (covered by warranty), If found, this will probably mean another 3 months on the hard waiting for the hull to dry pending repairs. If all goes well, it comes with a 5 year warranty at $5,880.00 for the job, this is half the cost of a deep peel and 2 layers of glass. Marty
Dear Marty,
I’m certainly empathetic to your problem.
I do have a suggestion. Before you commit to anything
call Rich Worstell at Valiant Yachts. He is a dear old
friend and probably has more experiance with
blistering than anyone anywhere. Valiant as you recall
had the biggest blister problem in the industry until
he purchased the company and reformed the building
process.
He is still repairing first generation boats, still.
Peel, drying and vinylester or epoxy coating is pretty
standard these days with a layer of vinylester soaked
mat if problem is deeper. Some anecdotal evidence
suggest vinylester is better than epoxy for staving
off future problems
Personally, I wouldn’t get too cranked up over the
problem because with the exception of a few boats with
fire-resistant resins andwoven only layups the problem
is limited to cosmetics. A good dry-out and recoating
works fine.
Don’t forget about the possibility of water migrating
from the inside as well. Bilge should be dry and even
coated if possible
If you want to contact me directly feel free to do so.
Jim
peeler.Equally distressing is the letter from Roger
not, “May 30, 2005 2:05 PM” looks like Rogers
additional gelcoat, so does this make 3 coats?Roger
throws all the estimates we have out the window… I
there.I took a look at some boats being
a 50’ catamaran gelcoat peeled and same process in
the works, looks to be more of a fare job than I’m
deep peel and 2 layers of glass.Marty
Do you Yahoo!?
Yahoo! Mail - now with 250MB free storage. Learn more.
Hi Marty,
I am familiar with your boat and knew John Perbaugh. I was there when the boat was hauled and the decision was made to do the blister job. I think the gel coat was completely removed by grinder. A barrier coat was applied and boat was back in the water in a week. Ala Wai Marine did the work. This was around 1994 but I'm not exactly sure. The blistering it had was primarily very small blisters but there were hundreds of them. Also there were a handful of quarter sized ones. So that's about all I can tell you about the blister repair.
Ron Thompson
Ho'okahiko #97
Do you Yahoo!?
Yahoo! Search presents - Jib Jab's 'Second Term'
