Stewart,
As always, there’s lots of ways to skin the cat. Because we stowed our 7’ Fatty Knees on the cabin top, there wasn’t room for a vang running from the mast to the boom. We tried a 4:1 tackle from the boom about 1/3 of the way out, down to the bulwarks. At first we tried to make do with one tackle, moving it from side to side. That was a hassle that we fixed by having a tackle on each side. We made the mistake of using blocks on the bulwarks end that had cam cleats attached. In light winds we could flick the line out of the cam from the cockpit, but at 15-20k, we had to go up to the block and jerk down on the line to free it. So, we changed the bottom blocks and put the cam cleats on the forward edge of the cockpit coamings. This has worked great for many years.
I preferred to avoid drilling through the boom to attach a bail, and instead used a dacron webbing strap with D-rings on each side, that wrapped around the boom, passing under the foot of the sail. The tackles attached to the D-rings with a snap shackle for easy removal when launching the dinghy.
When we’re off the wind, I pull the boom down with the tackle, from the cockpit. This isn’t as effective as a jibe preventer as a line from the end of the boom up to the bow, but it does stop the boom from slamming across to the leward rigging. In the case of the rare uncontrolled jibe, the sail backs but the boom doesn’t swing much past fore and aft.
In addition to flattening the mainsail and reducing sail twist, the stabilized boom reduces chafe on the sail. On the recommendation of our sailmaker (Shatthauer), I put sail mending tape on the seams where they met the rigging. After some use, you can see where the rigging leaves marks the sail. Of course each reef had it’s own set of tape.
When we’re running downwind on a broad reach, I let the boom all the way out, and it’s prevented from contacting the aft lower stay by the figure 8 knot in the mainsheet.
We’ve never been racers and so I admit that this setup may not be the last word for anyone interested in sailing the boat at its fastest. We did break our boom near NZ when a 35-40k front hit us. We were running downwind under the Aries with the seas on our quarter, discussing heaving-to at 2AM, when a BIG sea hit us on our beam and tossed us into the trough on our beam ends. The boom and it’s fully reefed sail were submerged, at about 7k! The boom broke about in the middle. No big surprise. Some folks put a rubber strap between the boom and the tackle–maybe a good idea, although I doubt if it would have saved our boom. After 29 yrs and about 55k miles, we’ve only broken one boom. Yeah, we should have been hove-to.
Dan BCC 59
