Jim:
Thanks for your response (also thanks to the others that responded). Jim,
were your problems with the BD1005 restricted to the inappropriately sized
flywheel, or did you have other problems as well? If so, I would appreciate
hearing about the other problems, either here or directly at my email
dioscouri@hotmail.com .
Thanks again!
-----Original Message-----
Sent: Thursday, December 18, 2003 6:42 PM
To: bcc@yahoogroups.com
Subject: Re: [bcc] Engine replacement
Gary,
I had that engine in a Contessa 32. It gave me quite a lot of problems
and there was no one to fix them. I ultimately found a dealer in North
Carolina who was sympathetic but not very helpful. If it was my boat
I’d stick with either Yanmar or Westerbeke. Lots of dealers,repair
persons and parts. It’s true that Beta uses Kubota but many of the
tractor parts don’t fit the marinized version. I had to replace the
flywheel because it was undersized and the engine kept stalling at low
speed. It took months to get the part.
The large tank holds 37 gallons. actually I believe that it is a second
tank below the primary.
Jim Hiller
On Dec 18, 2003, at 7:17 PM, Gary Mynett wrote:
My BCC (hull #64; launched in 1983) has its original raw-water cooled
engine, a Volvo MD7B. The engine still runs well, but is prone to
running
hot and is underpowered (about 17 HP) such that I am able to achieve a
maximum speed of just over 4 knots in ideal conditions (i.e., flat
seas and
tailwind).
As a result, I am considering repowering with a Betamarine BD1005
engine (a
28 HP marinized Kubota engine). I have heard many positive comments
about
these engines. Does anyone have any firsthand experience with these
engines
or comments on them?
On a 2nd and related matter, my BCC currently has the original fuel
tank
installed by the Sam L. Morse Company (which I believe is either 28 or
32
gallons). I am considering installing a larger fuel tank at the same
time
as I replace the engine.
Does anyone have a larger fuel tank installed in the standard SLM
configured
BCC? If so, what is its capacity?
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/bcc/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
Yahoo! Groups Links
