All things eventually end, and after 10 years with Finesse, I decided to make her available to someone who will use her for properly. For whatever reasons, I don’t have the time to cruise with her, so she should go to a new home and get to roam the seas, as she was intended to do. Currently, she is in Seattle, WA.
She is extensively restored and outfitted. Some photos attached. This probably is not catching everything, but here is an equipment list:
Yanmar 1GM10 9HP diesel engine
15 gal aluminum fuel tank
Lavac pump toilet with 15 gal rigid-plastic holding tank
12V macerator discharge pump
3 X Northstar NSB-115FT house-power batteries (330 AHr total)
Northstar NSB G-2400 start battery (920 CCA)
Blue Seas Systems 7610 SI automatic charge relay (ACR)
Blue Seas Systems 9003E on/off battery switch
ProNautic 1230P multistage battery charger
SmartPlug shore power cord set
DEI 30A Galvanic Isolator FSP
Divers Dream anode bonded to seacocks and shaft brush
3-blade bronze propeller
Jabsco Par-Max 1 automatic electric fresh water pump (1.1 GPM)
3M Cuno water filtration under sink
Brass water faucet
Raw water foot pump
Rule submersible bilge pump
Whale Gusher manual bilge pump
Groco bronze ball-valve seacocks throughout
Lewmar bronze winches
2 x Harken headsail furling/reefing systems
2 x Elliott-Pattison sails (main and yankee)
New Schattauer offshore furling staysail
Schaefer genoa tracks for jib with Garhauer blocks
Short tracks for staysail with Garhauer blocks
Garhauer traveler for mainsail
Garhauer boom vang
New dodger, sail cover, and entire interior cushions in 2011
Repaired and restiched canvas this year
Bottomsiders custom cockpit cushions
New poop deck with railing mounted on top of boomkin
NuForce Icon-2 audio amplifier
Kenwood KSC-SW10 subwoofer
Orb Audio Mod 1X stereo speakers
Wilson 803470 AG Pro-Quint Cellular Amp
Wilson 301130 marine cellular antenna
Raymarine ST2000+ Tiller Pilot
Maretron NMEA2000 network w/term resistors
Maretron GPS200 Receiver/Antenna
Maretron DST110 Triducer (depth, water temp, water speed) with M33-100 Bronze Housing Kit
Maretron WSO100 Weather Sensor
Maretron SSC200 Compass/Rate Gyro
Rose Point N2K/USB Gateway (Camano Light NT-50)
Actisense NGW-1-ISO NMEA2000/NMEA0183 converter
Ritchie Navigator compass and cover
PWR+ 12VDC 60W power converter (for Macintosh laptop computer)
Samsung 23-in Monitor (Mod # E2360V)
Custom teak laptop tray with cooling fan
RAM iPad mount
2 x StarTech ST4300USBM USB 3.0 hubs
2 x Blue Seas Systems dual USB charger sockets
eyeTV one television HD receiver with 2 custom UHF antennas
Garmin AIS 600 Class B transponder with GPS antenna
Shakespeare 5250AIS 3dB AIS rail-mounted antenna
Garmin VHF 300 transceiver with 3dB masthead antenna
Icom handheld floating VHF transceiver
Espar Airtronic D2 diesel furnace with two cabin vents and thermostat
King PAW-SS stainless electric marine heater (115VAC) with thermostat
Force 10 propane two-burner stove with broiler
25 gal fresh water tank
5-bottle wine rack in upper bilge (maintains wine at water temp)
Technautics CoolBlue refrigerator/freezer
Auxiliary 4-in fan added for compressor coil cooling
LED nav lights
LED cabin lighting
Cobra CPI400 400W power inverter
