I have a Garmin GPSmap 172c GPS installed and connected to a Raymarine ST4000 autopilot.
When the GPS is operating properly, it outputs a sequence of NMEA navigational data every 2 seconds. This NMEA data is used by the autopilot to steer a course to a waypoint. However, there is a problem with the Garmin software in that every day at 23:59:59 GMT, it will no longer transmit the NMEA information reliably. Sometimes the NMEA data stops entirely and other times it becomes quite erratic and is transmitted at 8 second, 20 second or some other random interval. When this happens, the autopilot displays a ‘No Data’ warning message and then steers the boat on the last valid course that it received. This behaviour continues until 00:08:34 GMT at which time the GPS reverts to the normal 2 second transmission interval.
I also have 2 Icom radios (M502 and M802), both of which are DSC capable and have a Lat/Lon display. When they no longer receive valid NMEA position information, the Lat/Lon display flashes, alternating between the last valid position received and a series of question marks. This is another indication that the GPS error is occurring.
I’ve been in contact with Garmin about this problem and sent them NMEA log files that showed the error occurring. (Software is available for Macs that will display the NMEA data in real time as it is being transmitted.)
After reviewing these log files, Garmin’s Technical Support department acknowledged that it is a problem in their software. The issue was forwarded to their Software Engineering department in November of 2006 and I was told that a fix would be provided in 2 weeks. When the 2 weeks passed, I was informed that it would be another month and when that passed, Garmin said that they didn’t know when a fix would be available. I’m still waiting for them to fix the problem.
When the GPS stops transmitting the NMEA navigational information, the autopilot maintains the last heading that it received. If that heading happens to be for example, a 30 degree course correction, then the vessel will be steered off course by 30 degrees until it starts receiving valid NMEA data again. I think that this represents a significant hazard and so I cannot rely on the GPS to maintain an accurate course.
I have notified the U.S. Coast Guard and submitted a ‘Consumer Safety Defect Report’ to them. I don’t know if they will pursue a recall or just some kind of advisory but this issue needs to be resolved one way or another.
The Garmin GPSmap 172c is running the latest firmware version which is 2.60, dated May 9, 2006. On the Garmin download site, the firmware for the GPSmap 172, GPSmap 178 and GPSmap 178c also have that same date for their latest updates. I’m trying to find out if this error also affects these units.
Is anyone else using any of these Garmin GPS units and if you are, do you get intermittent navigational errors with them?
(Mac users can download the GPSUtility software to display the NMEA data as it is being transmitted.)
