Hot water heaters
For the last number of years I have had a Bosch propane-powered hot water heater on board - it has never operated properly. I have had to continuously partially disassemble it in order to clean out the orifice that delivers the propane.
I have decided to remove that useless piece of equipment and am contemplating installing as Isotemp “Slim 15” hot water heater, which operates off either 110 volt AC or the engine heat exchanger.
Has anyone else installed an Isotemp hot water heater and, if so, what are your thoughts as to the quality of this equipment?
Dioscouri, #64
Gary,
Allcraft makes a 5 gallon unit that seems to get consistently high marks from end users. You can check them out at:
http://allcraftweb.com/
David
Rose 76
I use an isotemp on Stravaigin it seems to work just fine. Its heated off the engine and also 110, hasn’t let me down so far. It holds its heat very well.
