Jeremy:
In a conversation with Bill Miller, Sabb America, he stated two other G engine owers telephoned him about their engines running warm in the Bahama's. How did you add an impeller pump to your engine? Did you install a double pulley on the alternator?
Rod |
Rod,
My flywheel has two take-offs. One, the smaller one, drives the impeller pump. The larger one drives the alternator and the refrigeration compressor. I think the smaller take-off used to power an engine driven bilge pump which was originally mounted on the engine I think it was a gear pump not very much volume.
The impeller pump is mounted on a bulkhead on the pt side of the engine. The engine is mounted on heavy timber, not rubber engine mounts, so I dont get much movement.
-----Original Message----- From: Rod Bruckdorfer [mailto:seagypsy@att.net] Sent: Monday, August 20, 2001 5:10 PM To: bcc@yahoogroups.com Subject: [bcc] Impeller Water Pump - Sabb Engines
Jeremy:
Rod |
