FC 22 Hull #8 Asking Price $22,500. Located NJ USA
Contact Paul for more details: yorkshire6@verizon.net
Sam Morse built her in 1980, they installed ballast and decks and bulkheads.
Original owner took 4000 hrs to complete boat and launched in 1988.
Boat has sat on hard for 8 years now, needs engine reinstalled (new engine purchased 2009) as well as cockpit drain thru hulls.
Moving for work, forces sale.
Starting from bow:
New bronze bobstay chain plate in 2006
Chain locker, two hawseholes, one for rope (150?) and one chain (150?), chain is led thru a pipe and stows down low. Chain is attached to a 25 lb delta anchor that is mounted on custom fitting on bowsprit, no windlass. Second claw anchor
Next is a 3/4 berth with cushion and storage below, 2 6 inch portholes and custom made wood butterfly hatch over head (with bronze sliders and bronze security bars)
Next to berth is a custom cabinet with lid that holds a Groco manual toilet (purchased 2008, never used) with a plastic holding tank (under berth) and sea discharge (no deck outlet) - manual whale pump is used for discharge
Opposite berth is a cedar-lined space for clothes and fire extinguisher, also small seat and storage beneath
Custom entryway to main cabin with privacy curtain.
Stainless steel sink with whale foot pump (2008) that brings water from 2 ss tanks mounted beneath cabin sole (about 20 gal each) to a bronze faucet.
Custom cabinets around sink - joinery work is spectacular
Shipmate kerosene stove: burners, pump cup, one way valve and pressure gauge all replaced in 2008
Custom 5 gal kerosene tank for stove and lights (with deck fill) mounted behind cabinets with spigot below sink.
Two Weems and Plath kerosene lights (2008), 4 bronze 12 v lights snd ships bell on bulkhead
Large custom icebox with custom teak shelving and drain to bilge
2 full length berths with cushions and storage below and shelves above; all cushions in excellent condition
Custom electrical panel with map reading light on 3 foor cord (new 2008).
Twin Optima batteries (2008) with selector switch, volt and amperage meters (all 2008).
Automatic Rule electric bilge pump (purchased 2008).
Battery charger (purchased 2008) linked to 120V shore power circuit; circuit has 2x120V GFI outlets and circuit breaker
Radio/CD/iPod player with twin speakers in cabin (all purchased 2008)
Depth finder (purchased 2008) with thru hull transducer located under forward berth in custom box (spare transducer)
Garmin GPS 182C (purchased 2005 with Chesapeake blue chart) on swing out arm
ICom VHF with masthead antenna (purchased 2008)
Gimbaled compass with lighting (not installed), custom inclinometer
Universal M3-20A diesel engine purchased in 2009, not installed and never run.
New custom aluminium 20 gallon fuel tank, never used.
New racor fuel filter and fuel lines, not installed
New cutlass bearing, never used.
New 1 inch propr shaft (never used) with 3 bladed folding max-prop
Upgraded Admiral engine control panel (purchased 2008, 8 hrs use) with gauges for oil pressure, water temp, alternator output, rpm meter.
Custom teak cockpit grating and custom carved tiller (pivots to allow access to lazerette) with Ray marine ST-2000 tiller pilot (purchased 2008, never used)
Teak grating on boomkin and teak deck, all in good condition
2 primary Barient winches for genoa
Port and starboard jam cleats on cabin top for staysail
Mainsheet is on transom traveler, single 4:1 pulley
Deck mounted custom wooden mast and boom; over sized standing rigging and bronze turnbuckles.
Lazy jack on backstay for boom (no boom gallows)
3 Barient winches on mast, track for spinnaker pole and running rigging that could easily accommodate a cutter rig.
Three head halyards, one for main, one for genoa and one for chute.
Fourth halyard goes to block 2/3 way up mast, originally for staysail
Genoa on roller furler, line leads via block to cockpit
Steaming and deck lights, 3 way mast head light (new 2004)
Currently rigged as sloop with battened main and 110% genoa (both good condition), addition of a single stay makes her a cutter again.
No reefing lines but necessary cheek blocks, teak horn cleats and custom bronze tack hook supplied for installation
2 cruising chutes in bags (one with snuffer) that appear to be in good condition but I have never used.
Boom tent and weighted mesh cover for forward hatch
Matching covers for main winches, main sail, bowsprit and tiller (tiller cover in bad condition)
Spinnaker pole, PFDs, engine spares (all filters, anodes), 5 gal plastic diesel container, all manuals.
Overall canvas boat cover on custon frame.
Custom trailer - used this to haul boat from Wisconsin. Would need new axles and wheels.
