Have you drawn up a Maintenance Schedule for your BCC?
BCC 116 is over a year old and I’ve decided I need to be more
systematic about maintenance. I have started drawing up a schedule,
but I thought that perhaps someone has already invented the wheel and
even done it better than I would. Hence my query.
Of course, not all BCCs are the same, so not all items on a
maintenance schedule would be in common.
Below is my first try at a schedule, just concentrating on the
Plumbing system. I’d be v glad to hear if anyone has a schedule to
share.
Plumbing
Diverting Valves, Sewage and Water
Procedures:
Work (one open/close cycle), once a month
Checklist:
ħ Jabsco Y-valve (blue handle, starboard)
ħ Jabsco Y-valve (blue handle, port)
ħ Bosworth Y-valve (grey handle)
ħ Apollo diverter (yellow handle)
Vented Loop, Sewage
Procedure:
Unscrew and remove vent cap, check and clean rubber valve
Checklist:
ħ Groco vented loop (starboard)
Head
Procedures:
Flush with soapy water, once a month
Check position of seat and lid hinge, once a month
Clean seat and lid seals, once a month
Checklist:
ħ Lavac marine toilet
Seacocks
Procedures:
Work (one open/close cycle), each month
Check hose clamp for fractures or corrosion, each month
Checklist:
ħ Head, seawater intake (starboard)
ħ Head, waste out (port)
ħ Galley sink, drain outlet
ħ Genset cooling water and watermaker, starboard intake (mind the
sight gauge
for the lower fuel tank)
ħ Engine cooling water and sink, port intake
ħ Cockpit drain, starboard
ħ Cockpit drain, port (mind the red 12VDC cable)
Strainers, External
Procedure:
Open access door and clean, once a year or at haulout
Checklist:
ħ Genset intake (starboard)
ħ Engine intake (port)
Strainers, Internal
Procedures:
Inspect, daily when operating
Remove strainer cage and clean, as needed
Checklist:
ħ Engine strainer (starboard forequarter of engine compartment)
ħ Genset strainer (starboard cockpit locker)
Transom Ballcocks
Procedures:
Check hose clamp for fractures or corrosion, every 6 months
Checklist:
ħ Engine exhaust (starboard)
ħ Genset exhaust (port)
ZYGOTE, BCC 116
