Ok. Marty and others, once again the issue of MaxProp pitch vs Yanmar RPM.
What follows is an exchange I just had with David Swain at www.yanmarhelp.com. I find it hard to believe that the pitch is set all that much too high as it is more or less in line with what others on the BCC list have reported using in the past. Is it possible that my tachometer is reading waaay low? Or should I go a lot lowere than the present 18 degree setting, to 14 or lower instead of the 16 I intended to try next time I haul out?
Opinions welcomed.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Quoting Scott to YanmarHelp
Another question. As purchased, the boat (a Bristol Channel Cutter) was set up with a 15" MaxProp set at 22 degrees of pitch. Engine RPM/speed curve topped out around 2400 RPM, so last year I reset it to 18 degrees pitch and now it cruises happily around 2200 RPM and tops out around 2750 -2800. I am inclined to reduce the pitch further to 16 degrees to increase the max useful RPM. What do you advise? What RPM and length of operation at that speed would be pushing the limits for good practice with this setup? Up until now I have never noticed any black smoke at all, unless pushing hard at top RPM, not something I routinely do.
Regards, Scott
Yanmarhelp.com Posted: Jan 27 2006, 10:32 PM
Administrator
Scott you were massively over-proped you should me able to reach 3600rpm If your are using the Yanmar tacho that’s about 3700 as they under read by about 100rpm at the top. probably why you’ve experienced the head gasket failure. You definitely need to decrease pitch further. Not sure how much adjustment you have but you need to pick up another 800-900rpm!
Dave Swain
Marine Power Ltd. - UK Yanmar Dealer
