Mooring ball procedure
Hello friends I’m on my BCC maiden season in the PNW, figuring out systems as I go. What is the best procedure for securing to a mooring ball? I’ve set up a bridal running out the starboard hawsehole. Then attached the anchor snubber to the bridal to keep the ball off the hull and clear of the bobstay. Is that acceptable or is there a better method? Advice appreciated.
It would be better if you did a true bridle, ie a line from both starboard and port. Just going out one side you may find the boat oscillates more. Also, if it’s a long term stay, double up the bridle - two lines through the mooring eye.
Thank you for the feedback. Actually, my question is more related to the technique of keeping the mooring ball off the hull. Using the anchor snubber worked fine for that so I’ll just use that technique in the future. Cheers.
