I must say that Sumio’s and Roger’s response to the quality concerns over
the Cherub are very encouraging. What is not encouraging however is the
statement that the Cherub has been discontinued because of the high cost of
building it.
Please clarify, Sumio. Is it still possible to acquire a completed Cherub?
Or will you sell the Cherub only in kit form?
I have seriously considered acquiring a Fatty Knees but have now come to the
conclusion that the Cherub is preferable. Hopefully it is still a viable
option!
-----Original Message-----
From: Roger Olson & Sumio Oya [mailto:info@samlmorse.com ]
Sent: Thursday, January 10, 2002 3:33 PM
To: bcc@yahoogroups.com
Subject: RE: [bcc] nesting dinghy
Importance: High
Russ and the BCC group,
I am sorry you have found some problems with the Cherub. I have discussed
this with Roger Olson and our combined response is the following:
Our intention from the beginning was to build a quality dinghy that would
set over the scuttle hatch on the BCC. The hull is laid up by Crystaliner
and they assured us that is should not have any blisters. Lets face it,
they were wrong. For this I apologize and am willing to reinforce any
reasonable costs you incurred. In the future all our Cherubs, like the BCC
and FC will have a vinylester gel coat below the water line to prevent any
possibility of osmosis.
There were never any galvanized fasteners used in the Cherub. We use only
stainless steel. We do not even have any galvanized screws in our factory.
Now, I must also admit the stainless we order from West Marine does rust
because it is 316. We cannot use bronze to screw into the fiberglass, it
will break. If you have any screws left over that you suspect are
galvanized, I would certainly like to see them.
Your comment about the stainless steel leeboard shaft is a good one. A half
inch shaft threaded is reduced to about 3/8" which is not strong enough to
take the loads on the leeboard. You are the first one who has complained
about this problem but it certainly make sense and all future leeboards will
be pinned.
We have always suspected the gelcoated seat may be a problem. Crystaliner
assured us that it would be ok. Since the Cherub is relatively new, it has
not had time for the true test. However, we certainly do not question what
you say. You are not the first to have this problem. The only solution is
paint or teak and teak is just too expensive to make standard. We looked
into a solid plastic material but it, like other alternative make the price
outrageous and/or ugly. We are open to suggestions.
The cost to build this dinghy is so high that we have discontinued it
because we cannot build it and make a profit. We will gladly build a “kit”
boat or just the hull. However, I suggest we build in the floatation in the
floor. The problem is we must pay our men a reasonable salary and it takes
many man hours to produce a finished boat.
I want the group to understand that we do the best we can with some cost
restraints. We do not and will not cut corners like using galvanized
screws. We also admit that this is a new product to serve a special
purpose. It is not possible to build it like we would like and still sell
it at the same price. I suggest you check the quality of the Fatty Knees
and its price.
Roger had inflatable collars made for his Cherub that snap into eye straps
that make it easy to install and remove. It makes it excellent for climbing
in or out from the water. Perhaps you would like to ask him at
roger.olson@att.net
We are here to provide any assistance we can to our owners and I personally
promise to keep the high standards of the past. If anyone has any
complaints about any of our products, I want to know. Our objective is and
has always been quality. Please feel free to email or call me with any
suggestions. Our BCC is where it is now by input from its owners. We have
made many improvement but all these cost money. As you know, the price is
now higher than any of us would have expected. It is either this or close
the factory.
I need the suggestions from the owners. If you do not give me suggestions
then I presume everything is ok.
Sumio Oya
From: Russ Burchfield [mailto:landlubber77586@yahoo.com ]
Sent: Wednesday, January 09, 2002 1:07 PM
Hi Gary,
Yea that is the Sam Morse dink.
Now that I think of it. I have some more comments.
Good and not so good. And things to watch out for.
Now, out of the box the dink looks just superb! In
every respect. But it is just that 16mos. of regular
use in the E. Carib. has brought some deficiencies to
the surface.
First let me say that this is a great sailing dink.
We think it is more fun sailing with a reef in and
15-18 kts of wind than less. I even hiked out on the
rail a couple times.
Don’t let anyone tell you anything bad about a
lee-board. This boat sailed great on both tacks
without switching the board.
The lee-board bracket is a very robust aluminum
casting. But the mounting rod is stainless, about a
foot long X 1/2 in. dia. and threaded into the bottom
of the casting. Our mounting rod broke at the
termination of the thread. This is a natural weak
point. They would be better off just inserting the non
threaded rod into a blind hole in the base of the
casting and cross pinning it or set screwing to retain
it. Which is how I repaired it. No further failures
in that area.
The three seats offer many seating options. We even
drilled more positioning holes to suite our purposes.
But the seats themselves are gelcote over plywood. It
took only a month or so of sitting on them before the
jelcote cracked all over from the flexing of the seat,
and peeled off in large chunks. Jelcote is brittle
without reinforcing glass or other cloth.
While I am thinking about it… we made a long narrow
canvas bag to carry the entire sailing rig,
seats,rudder and leeboard. And it resided either on
the side deck or next to the hand rail on the cabin
top. Worked great.
As we intended this to be a work boat/dink and not a
showpiece, we ordered it with the cloth covered foam
rails. This worked great in not banging up the
topsides of the mothership and other peoples boats.
when bring it along side and raising on and off deck.
Not to mention more bright work to worry about.
We do not believe that Sam Morse would condone the use
of non stainless fasteners in any of their products.
We just don’t know what happened here.
The 2hp. 4 stroke Honda we primarily used worked just
great and pushed the dink at 5-6kts. Which worked
just fine for us. I think a 3hp. is max. and a 5hp
would likely flip it over.
If you order one you should get an epoxy barrier coat
under the jelcote. Or some other resin system in the
layup.
I think that all of the above is just the querks of a
new but otherwise superb product.
I have talked to Rojer a long time ago about this. I
hope that the feedback was constructive as intended.
Let me know if you have any more questions.
Russ…
