Figured I would share this with the forum…
Below is a partial listing.? We can also provide cleats, chocks, bits/bollards, sprit heel socket with Sampson posts, blocks, port holes, turnbuckles, gooseneck, mast cap, traveler, genoa cars and track, outhaul car, thimbles or just about anything else you might want for your boat. ?
Thank you for the inquiry.
Cathy L. Langley
Port Townsend Foundry LLC
251 Otto St
Port Townsend WA 98368
V-360 385 6425
F-360 385 1947
The bigger the dream,
The larger the reality!
Bristol Channel Cutter:BCC Rudder fittings
Complete BCC rudder fittings package Machined
1,539.11
Bristol Channel Cutter:Bobstay Fitting 2 holes
Bobstay Fitting? 2 Holes
322.00
Bristol Channel Cutter:Boomkin bottom plate
Boomkin bottom plate 2 tangs
213.60
Bristol Channel Cutter:Boomkin stays
Boomkin stays BCC
65.89
Bristol Channel Cutter:Boomkin top plate
Boomkin top plate single tang
207.60
Bristol Channel Cutter:Bow Roller Bracket
Double Spindle Bow Roller Bracket
1,036.80
Bristol Channel Cutter:Bow Roller Saddle
Bow Roller Saddle 5.25 Octagon
1,452.00
Bristol Channel Cutter:Chainplate Set
Chainplate Set (6)
777.60
Bristol Channel Cutter:Gallow Bases
Gallow Bases (Large)? price per each…(takes a pair)
109.00
Bristol Channel Cutter:Gallow Brace Support Fixed
Gallows Brace Support Fixed (pair)
471.60
Bristol Channel Cutter:Gallow Corner Frames (Large)
Gallow Corner Frames (Large) pair
435.00
Bristol Channel Cutter:Gallow Supports
Gallow Support & Bases Adjustable pair
555.60
Bristol Channel Cutter:Gallow Tube, 41" long
Gallow Tube, 41" long (pair)
201.60
Bristol Channel Cutter:Gammon Iron
Gammon Iron without rollers
624.00
Bristol Channel Cutter:Hawse Pipes, Deep, Pair
Hawse Pipes, Deep, Pair 2.94"?? (4 pair)
237.60
Bristol Channel Cutter:Hawse Pipes, Shallow, Pair 1.62
Hawse Pipes, Shallow, Pair 1.625"
237.60
Bristol Channel Cutter:Kranze Iron
Kranze Iron 2.75" ID
458.40
Bristol Channel Cutter:Lifeline Stanchions
Lifeline Stanchion with Deck Base, priced per each? (takes 10)
319.00
Bristol Channel Cutter:Sampson Post Caps
Sampson Post Caps per pair
58.80
Bristol Channel Cutter:Whisker stay chainplate
Whisker stay chain plate for BCC-Pair price
184.02
Bristol Channel Cutter:Winch Bases
Winch Bases each
390.00
