Scptt:
I published the following on the forum sometime ago. In summary, on small boats, the size of the radar array is not as important as the size of the display screen. Depending on range, large screens show clear separation of targets, whereas this is not always the case with small screens. Range is dependent on the height of the target and the arrray above the water. If the array is mounted at 20’ and the mean height of the ship is 50 ft. above the horizon, the line of sight range is 16nm. If the array in the above case is 10 ft above the water, the range is 12nm.
Thoughts on Radar Array and display size:
We installed a Furuno 1623 unit on our BCC and friends have one on their Falmouth Cutter 22. Because the radom array is 15" (33.6cm), the unit looks “just right” for the boat size. The trade-off between a 15" (33.5cm) and an 18" (40.3cm) array is a decrease in resolution.
In terms of resolution, let’s discuss the distance two targets (ships) must be separated before two dots are resolved on the display screen. For our purpose, I will assume the range to the targets is 4 miles (6.7km) and the radar beam intercepts both targets at the same time, i.e. both ships are in the same plan as the signal at the same time.
For an 18" array and a target range of 4 miles, the two ships must be greater than 642 yd. (~593m) apart before the two ships are resolved into two targets displayed on the screen, whereas for a 15" array the two ships must be greater than 766 yd (~707m) apart. If the distance between the two is less than 642 yd for the 18" array and less than 766 yd. for the 15" array, only one target is shown on the display screen. This is under ideal condition. In terms of a percentage, the 18" array has about 16% better resolution than a 15" array at a range of 4 miles.
The probability of two ships being that close together and in the same plane at the same time as the radar beam signal cell is low. Even if all conditions are not met, one will see at least one target on the display screen.
Radar resolution comparisons do not provide the complete answer. The real limiting factor on a sailboat is the screen display area. For our purposes, let’s assume the display unit has about a 6" (13cm) screen. At a range of 4 miles (6.5km), the display uses about 3" (6.7cm) all around the center point, to show the 4 mile {about 7,000 yd (~6,500m)}. If the two ships are 1,000 yd (923m) apart, the ships are displayed as two dots separated by a space representing 1/7th of the 3" portion of the sceen, i.e. the two dots on screen will be about 0.4" (1cm) apart. If the two ships are 800 yd (738cm) apart, the two dots on screen are 0.3" (0.7cm) apart. If the radar range is set at 8 miles, the distance between the two dots on the screen is halved for the above, i.e it becomes more difficult to distingish one target from another target as the radar range is increased when the display screen is 6" (13cm) or 7" (16cm).
The above discussion, became very real when I worked part time on tug boats after I retired from chemistry/engineering. Besides using large radar arrays, tugs employ large display screens.
While I am on this long rambling spell, let’s talk about range. If the radom is place 20 ft above the waterline and we assume the mean height of the ship is 50’ (15m) above the water, then the earliest detection distance under ideal conditions is 16 miles regardless of whether the radar unit has a 16 mile range (27km) or a 72 mile (120km) range.
In summary, the limiting factor for small radar units is not the resolution or range of the unit but the size of the screen. Ideally, I would like to have a radar unit with a 15" (37cm) array and a 12" (27cm) display screen. Unfortunately, the sales/marketing wizards have other ideas.
You may wonder why I selected a Furuno unit. I selected Furuno because it is the manufacture that one sees almost universally in the commercial marine industry.
If you are interested, “radar range resolution calculation” are available via the Internet.
In closing, there is one other factor which is probably just as important as the equipment and that variable is the skill and experience of the operator.
BCC IDUNA
