I have had the same problem with the staysail sheets catching on the whisker
pole or the mast winches and maybe the doghouse. I have mostly solved that
problem by maintaining a little tension on the lazy sheet with one wrap on
the winch and while tacking as a let off the working sheet I simultaneously
pull in on the new working sheet not allowing any slack to develop. That
usually prevents it from catching on anything.
Hope that helps.
Ron
Ho’okahiko #97
To: bccforum@samlmorse.com
Sent: Tuesday, April 19, 2005 6:23 AM
Subject: [BCC Forum Post] joliebrise: staysail lines snag on doghouse
Author: joliebrise
Username: joliebrise
Subject: staysail lines snag on doghouse
Forum: BCC Forum
Link: http://www.samlmorse.com/forum/read.php?5,3997,3997#msg-3997Does anyone else have this problem? Sometimes, I think too often, when I
tack the staysail, the line on the new tack snags on the forward leeward
corner of the doghouse, requiring me to go forward to free it. I’m
thinking of attaching a cheek block to the doghouse. Has anyone got any
better ideas?Thanks,
Jonathan, i.e. Jolie Brise.
