I’m new to the list, and new to Cutter ownership. My Bill Garden designed “Spray”, a 27’ OD, 35’ OA Channel Cutter Replica was recently rebuilt (wood hull, 1960) and I’ve been out sailing on S.F. Bay only 3 times since.
I rigged the bowsprit last night and up to now have been sailing under main and club footed foresail. Now the jib will be an option. Her sprit does not lend it self to crawling out to bend a jib. The stays on either side of the sprit are in the same plane as the bowsprit, so using them to climb out on isn’t very
realistic for bending the sail, or loosing gaskets, or hauling it in.
In my box of rigging, is what appears to be an “outhaul”, where a ring rides on the sprit. From what I gather, the “stay” for the jib is “mobile”, i.e. you bend the sail to the stay, then haul the stay out on the 'Sprit, then hoist the stay/jib?
Not sure how the rig should go together…
