For her 15th birthday, we replaced Zygote’s chainplates and standing rigging, replaced one conduit in the mast, and repainted her mast, boom, and mast step.
Next on the list is to replace what are variously called shroud tangs, strap tangs, or sometimes shroud plates: the stainless steel plates that are bolted (in Zygote’s case) to the hounds and to which the shrouds (and the forestay) are made.
I include photos to show what I mean.
Based on the rule of thumb that 316 stainless steel has about a 20 year working life, I figure I need to replace Zygote’s shroud and forestay strap tangs within 5 years.
Any commercial sources for BCC shroud strap tangs? Or has it been just a case of taking drawings and going to the local fabricator?
I think the cap shroud tangs and the intermediate shroud tangs are identical. The lower shroud tangs are double, handling both fore and aft.
I’ve not seen specs or drawings for the shroud tangs, other than a post Roger Olson made to the forum in 2008, in which he noted the centre-to-centre length of the cap and intermediate shroud tangs was 3.5" and that for the lower shroud tangs was 5.75" (see: http://samlmorse.com/forum/read.php?5,7229,7239#msg-7239)
I note that Rigrite.com sells some shroud strap tangs, but none that look the right length (see
http://rigrite.com/Spars/SparParts/Tangs-complete/Tangs-complete.htm)
Ron and Stan’s company has a small selection of shroud strap tangs, again nothing of appropriate size (see http://www.ronstan.com.au/marine5/range.asp?RnID=108).
I’d be glad to hear your experiences changing shroud tangs. In Zygote’s case, with a Forespar mast, I know the compression tube on the through-bolt through the lower hounds is captive. But the compression tube on each of the through-bolts at the intermediate and upper hounds is loose, so those through-bolts are best withdrawn with the mast vertical.
And for something completely Off Topic:
While Zygote was up on the hard, one of our friends at our marina started a solo unassisted west-about circumnavigation.
Bill Hatfield spend July thru August getting his Moody 33’ “Katherine Ann” in shape and set off with a notional start/finish line just outside Moreton Bay (i.e. in the Pac O).
Bill ran into trouble early with his windvane self steering, so he aborted and called into Sydney Harbour to get a spare part. That was in early September, 4 months ago (see: http://www.sailblogs.com/member/whatfield1/?xjMsgID=371789).
He is now closing on his turnaround point (Horta, in the Azores - chosen to put him as far N in the N hemisphere as Sydney is S in the S hemisphere). See Bill’s blog at: http://www.sailblogs.com/member/whatfield1/ He’s a good chance of a time record for a solo west-about.
