Ahoy Jeremy, my BCC “Calliste” as a used boat , came with a ICOM SSB already installed.
I have used that rig, time and time again, it has saved my bacon, especially when Bil of BCC Zygote, while in Penang, Malaysia, sent me daily weather forcasts, over Sailmail, even as I was at sea , and, approaching Bali, from Oz, after the bombing there in 2002.
As a single hander, back then , you can not even know, how much it was a comfort, to read Bil’s prognastigation of weather and political reports, while I was onroute and otherwise out of touch, at sea.
I heartedly support a SSB rig onboard, for cruising away from home waters, while on route to unknown foreign ports, and even while visiting them !
My Icom tuner is mounted as you plan, on the transom, in the lasserete, but the factory installed 3" wide copper conductor and bronze screening , thru-out the hull as a R F ground, was a bad idea. It was f/g’ed encapsulated on the inside the hull, which later proved either a bad idea or a bad installation, because condensation entrapped along the 3" tape line and all along the bronze screen , corroded that copper, and entrapped moisture all along that bonding strip and screening .
My take though not proved would be to drop over the side a bonding plate, to act as a R F ground, then take it back up onboard, when not in use, even while underway !
To have that “sailmail” coms, while underway is very precious, and when out cruising , becomes invaluable .
It is worth every effort to get it, onboard, if knowledge and communication, is of interest to you.
My back stay has Norseman insulators, and the tuner was able to adjust the visable radio output to compensate for an unconventional length antenna .
I never needed to use my lifelines as antenna extensions, and my life lines are 1 X 19 ss un-coated wire , for reduced maintaince.
IMO , if you are doing cruising in unknown foreign waters, you won’t be dissapointed to use your SSB and it’s email as coms, onboard your boat !
I haven’t used GRIB files for weather info, but many others have and swear by that too !
Douglas
