I’m planning to replace all of the standing rigging (wire) on Sea Wind over the next month or so. As I put together my parts list and plan the job, I’m weighing the decision between traditional machine-swaged fittings and mechanical fittings like Sta-Lok.
I’d love to hear from anyone who has re-rigged recently or has long-term experience with either route. A few specific points I’m thinking through:
DIY vs. Professional Setup: Sta-Lok fittings are appealing because I can install them myself using standard hand tools right at the dock or yard. For those who have gone this route, how straightforward was the assembly process for a first-timer?
Reliability & Inspection: How do mechanical fittings hold up against moisture and crevice corrosion compared to swages over 10+ years?
Cost Difference: Sta-Loks carry a higher upfront hardware cost, but being able to reuse the fitting body and only replace the internal wedge/cone in the future seems like a solid investment. Has that played out as expected for you?
Hybrid Options: Has anyone opted for swages at the masthead and Sta-Lok at the deck level to balance initial cost while retaining field repairability?
If you have any lessons learned, strong preferences, or advice between Sta-Lok, Hi-MOD, or standard swaging, I’d really appreciate your insights!
Hi Lima - we replaced Calypso’s 1976 wood mast with a production aluminum spar (Selden/Charleston SC) a few years ago. I elected to get new standing and running done by Selden included in the order. Because there were variance in the old and new geometry, the supplied new standing rigging was all swaged aloft, but Sta-Lok at the chainplates. I am happy with that. The rigging shop at Selden/Charleston are very competent, they have the right equipment (hydraulic swaging machine) and the the swages look great. We previously were all Norseman mechanical fittings on the wood stick and never had any problem with them. The Sta-Loks are high quality and I trust them.
When engaging a rigger to do swaged rigging, experience and swaging equipment matters. Ask about it. Ask to see samples of their finished work.
I would have no qualms going all Sta-Lok and doing the work myself. Yes, the terminals may be more expensive that swaged fittings, but the net cost might prove to be a wash by the time you by the hardware from a competitive retail source and do the work yourself.
Wire matters. I have seen and heard a few stories about 1x19 failing within 5-10 years. The typical reported failure is individual strands breaking at the swaged fitting. There seems to be a lot of low quality SS wire out there - so doing some research and insisting on cerificates of origin might be worthwhile.
Another option is skipping wire and going with heat treated pre-stretched dyneema. Gary Felton (@seacap) has rigged Angelsea that way for many years.
Being that I am in L.A. Harbor I have a very good rigger (he does Trans Pac Boats) I can use and that would be for swaged both ends as he does not do Sta-Lok’s his quote is $1000 over the online quote from Vela Hybrid Option. Im leaning towards Vela.
I have a combo of Sta-loks and Norsman fittings both top and bottom on my boat. The entire boat is rigged this way, even the bow sprit. I bought the boat rigged this way. I’m approaching the need to re-rig the boat after 8 years of ownership. I have been happy with them and it will be a plus when I redo it all. A factor to consider is how long you will own the boat. If you will not own the boat longer than 10-12 years after you redo the rigging it’s probably not worth the additional investment in Sta-Loks. You won’t need to re-rig in your ownership. You will not get more money when selling the boat with Sta-Loks than not. I am happy with my fittings, I and others feel there is less stress on the wire with them. However when I had a rigging survey when I bought the boat the rigger really PoPoed them. Obviously they are not a great way for him to make money. Last there are additional brands on the market now that are very high quality but expensive. Some of the older brand went out of business recently so finding replacement parts has gotten more challenging.
Just wanted to post an update and close the loop on this thread. After crunching the numbers and talking directly with the vendors, I’ve decided to go with Vela Sailing Supply for the new standing rigging package on Sea Wind.
Here is why I landed on this route:
The Hybrid Setup & Components: I’m sticking with the hybrid plan we discussed—using KOS Grade 316 wire, factory roll-swaged Hayn terminals on top (done on a WireTeknik machine), and Sta-Lok mechanical eyes on the lower deck ends for easy adjustment and serviceability.
Significant Cost Savings: Getting the package through Vela saved me roughly $1,600 compared to the local shop quotes once local tax and retail markups were factored in.
Vendor Responsiveness: Working with Rod over at Vela has been great; they were straightforward about their hardware, swaging equipment, and custom options.
