The Head
I am in the process of installing a holding tank, replacing the toilet and
all the hoses, and cleaning up the space. Basically a general overhaul of
my head. As such, I’ve been diligently researching best practices. The
most common practice for head installation, by far, seems to be the classic
vented loop intake to the toilet, followed by a vented loop outtake to the
holding tank if the tank is below the waterline. However, I found this link
which I thought was interesting.
http://www.sailcopress.com/editorial%20MSD.htm
Does anyone have this kind of installation? I love the simplicity of the
design and, as someone who feels increased peace by shutting the intake
seacock after each use, I wonder how important the vented intake loop is for
safety. It would be best if I could get the lip of the toilet above the
waterline, but I am not sure that’s practical. Still, there would need to
be a double failure for a disaster to occur - the seacock failure/left open
and a toilet value failure.
As a beginner, I guess I am looking for someone to tip my opinion one way or
the other or, at the minimum, maybe just start some controversy. :wink:
Paul
BCC Misty
Paul,
I owned an Albin Ballad many years ago that had it’s holding tank set
up that way. You pumped up to the tank and gravity did the rest. It
worked perfectly. I suppose that some factors which you may consider
though are the effect of weight above the waterline on trim and
stability, leakage and rupture above the waterline and potential
backflow .
The Lavac which currently is supplied by SLM works very well and
certainly could be adapted.
None-the - less, my .02 is go for the conventional set-up. It is
without any of the aforementioned potential problems although the Lavac
does requite a vent to bleed off vacuum pressure.
Jim Hiller
and
overhaul of
The
classic
the
this link
the
is for
the
need to
open
way or
Paul
BCC Misty
Yahoo! Groups Links
http://www.hillersmarkets.com/
Paul,
I ( shipyard) installed a new system on Sea Star last year.  I purchased tank, Sealand pump and all fittings from Oceanlink.   Unlike the schematic on their website I have no vented loop in my overboard discharge line. With the seacock valve, a check valve, a positive displacement pump and, the flush valve providing protection from the sea, Oceanlink suggested that the vented loop was a backup for a redundant backup. The premo tank level indicator is the way to go if you have some spare height above top of tank. I like the system and the people at Oceanlink are knowledgeable and helpful.
David Kent
Sea Star
[David W. Kent]  -----Original Message-----
From: Worner, Paul [mailto:paul.worner@thomson.com]
Sent: Tuesday, September 28, 2004 10:50 AM
To: 'bcc@yahoogroups.com'
Subject: [bcc] The Head
my head.  As such, I've been diligently researching best practices.  The
waterline, but I am not sure that's practical.  Still, there would need to
the other or, at the minimum, maybe just start some controversy.  ;-)
Paul
BCC Misty
Hi Paul,
So, you are the Head Mechanic! Nice!
Just remember, if you do sell your boat one day, you want it to pass the survey and you will therefore want the famous vented loop!
Wish you were at the Lyle Hess Tribute to inspect the plumping options!
 Kate
Kate Christensen
RogueWave Yacht Sales & Services, LLC.
1806 Dreams Landing Way
Annapolis, MD 21401 USA
410 571-2955 Office
410 703-5008 Cell
801 681-9741 Fax
Hi Kate,
That's a good point.  Based on the feedback from Jim and David, as well as yourself, I am starting to lean toward the "classic" setup with a Lavac system.
Yeah, I wish I could have made it.  I was thinking about that as well.  Not only plumping options, but ideas for the forward compartment as a whole.  Maybe next time.
Take care and say hi to Bernie,
Paul
From: Kate Christensen [mailto:kate@roguewaveyachtsales.com]
Sent: Tuesday, September 28, 2004 2:13 PM
To: bcc@yahoogroups.com
Subject: RE: [bcc] The Head
Hi Paul,
 Kate
Kate Christensen
410 571-2955 Office
410 703-5008 Cell
801 681-9741 Fax
Paul:
I’ve lived with the standard Lavac set up for three years now. The head
is great. I have removed the holding tank to overboard connections as I
sail the Great Lakes and that’s not an option here. I am thinking about
changing the connections for my y-valve to have the head to overboard (for
#1) be the vented loop connection and to plumb head to holding tank direct
with a short run off the y-valve.
My goal is to use less water per flush into the holding tank yet clear the
hoses completely. Initial calculations suggest I would have to be sailing
at about 50 degrees with a completely full holding tank before I needed to
worry about siphoning back into the head. More measuring this winter.
I would suggest using SeaLand hose for the runs. They also make pvc hose
end fittings that work well. You can then buy the 1 1/2" pvc 45 and 90
degree bits at any hardware store…don’t buy the SeaLand versions.
Hope this is useful…Tom
