Does your BCC have a water speed transducer of the
sort that comes with a bung that plugs the thru-hull
when you’re not sailing? I have a Raymarine ST60 water
speed system of that type.
My problem, big enough to make me put the ST60 water
speed system in the category of ‘Things that work,
imperfectly’ is handling the ingress of water when I
change the bung for the transducer or vice versa.
Don’t get me wrong: I enjoy the ST60 water speed
system on Zygote. Combined with her Raytheon ST60 wind
system, it gives me true wind. And combined with her
Raytheon Raychart and GPS, it calculates and shows
tidal stream vectors.
Has anyone worked out a way to minimise the in rush of
water when changing bung for transducer? The flapper
valve in the thru-hull reduces the flow, but is a
joke. Zygote’s thru-hull is near the foot of the mast,
so after every change I flush the area with
freshwater, wax the mast, and spray nearby electrical
connections with silicone.
I’d be grateful on tips and tricks dealing with the
water speed transducer. In return, I’ve attached a
file (bilgepumps.zip, about 80K), with the HTML
version of the section on bilge pumping in my
growing-but-not-finished Operating Manual for Zygote.
BCC28 #116 Zygote
http://mobile.yahoo.com.au - Yahoo! Mobile
- Check & compose your email via SMS on your Telstra or Vodafone mobile.
