Hi Ben,some comments inserted below, plus another view of Itchen’s installation.
benjiwoodboat Wrote:
Here we go again! I’m thinking out loud here with
questions…
I’m trying mount this TP32. I like Scott’s
mounting location pictured here, it’s clean and
gets the TP at the right height, without too much
extra hardware:
Oh yes I remember that cold and frosty January morn at anchor on the Pungo River, with skim ice all around and coffee brewing and a red hot flowerpot over the other stove burner to tame the chill in the cabin. Anyway, re tiller pilot mount …
Scott, I don’t understand how you got that to fit
with the cleat there!?! And besides just fitting
it there, doesn’t it interfere with the cleating
of the main sheet?
There’s no interference with the main sheet because we have big Harken swivel-base cam cleats. Definitely the way to go, much better than regular cleats especially when singlehanding ,or really, anytime. I like the Harkens – solid, robust, trouble free, reassuringly expensive . . . .
Too bad I didn’t take any good
pics of that last summer at the rendezvouz.
See attached photo (which also shows my less-than-ideal Cape Horn vane adjustment setup).
The Simrad TP 32 says it has a throw of 10". My
tiller has a throw of 21" @ 18" from
pintle/guedgon. Is it necessary to have the full
throw with the tiller Pilot, or is it good enough
to get 50% throw? While perusing this thread yet
again, I see Tom’s setup, which I also like very
much, pictured here:
Tom, it looks like you don’t have an extension
installed, which I assume limits the throw to 10"
= standard Simrad TP32 specs, thus your tiller
pilot can only go 50% to one side. Is that
correct, and if so… how has that worked out for
you?
Getting back to Scott’s mounting location on the
boomkin, to avoid the mainsheet cleat interference
I’ve seen some jam cleats on the main sheet, as
per Tom’s pic:
I assume that eliminates the need to sheet to the
cleat, this freeing up that space for a TP mount.
However, that cleat also functions as a dock
cleat, does your mount get in the way of that?
Absolutely. With the TP pedestal at the very end of the boomkin, the factory-mounted position of that big cleat is right up against the pedestal with only a fraction of an inch to spare. For dock or anchor lines there are various work-arounds so I have not gotten around to moving the cleat, but it really should go back aft an inch or two. When at dock I sometimes just unbolt he pedestal.
I’ve called around a fair bit and am finding the
90mm pedestal base like Tom has to be out of stock
everywhere, and Simrad/Navico even said they don’t
know when it will be available again. Looks like
I’ll have to make my own pedestal mount.
Have you tried the Nautical Trader in Nokomis FL? Great source of ever-changing array of useful and useless hardware and odds and ends.(www.nauticaltrader.net)
Ramble appologies…
Thanks!
Ben Eriksen
BCC #91 Elizabeth
Web Design | BCC Elizabeth
