Thanks Bil, that picture is VERY helpful.
I spoke to one of the  older guys at my marina and he said, given the age  of BCC77, that it is possible that if the mast has not been unstepped and conduit added, that you might just have bundles of cables + wires tapped together without conduit.
That person said he was not clear when conduit became the rule for aluminum mast extrusions.
Late addition: if you have conduit inside your mast, then the conduit is pop-rivetted to the mast every few metres. So if you see pop rivets running in a couple of lines up the mast, you have conduit.
The deal with conduit is that it supports cable and wiring, and stops them (among other things) slapping against the inside of the mast.
Yet another late addition: Zygote’s mast has two conduits. One runs to the masthead (with VHF cable, wind indicator cable, and wiring for the masthead light). The other runs to the hounds, carrying the radar cable (i.e. Zy has a mast-mounted radome) and wiring for deck lights and low-level sidelights (used when steaming). So Zy has two lines of pop rivets. You might only have one line if you only have cabling to the masthead.
Do you recall what type of support/bracket held
the weight of the VHF cable near the top of the
mast?  I assume it’s not just held by the weight
of the connector?
No, you cannot have the weight of 13 metre of cable applying tension to the antenna connector.
Zygote’s VHF antenna is mounted on a bracket to starboard. The cable is lashed to that bracket with a couple of supposedly UV-resistant cable ties. Then the cable - surrounded by a supposedly UV-resistant sleeve, curves before it enters the mast. I think that the lashing plus the friction at entry to the mast does a fair bit of the supporting of the cable mass. I’m unclear about other support.
Another late addition: I don’t remember any other supporting structure (but I have trouble remembering what I did on the day before yesterday and occasionally I have to hunt for the car keys!
See (taken before the mast was re-stepped of course): masthead.jpg
