CONCEPT: BCC as a staysail schooner
Your proposed main mast (33′ deck to head, solid DF, 6° spreaders) would become the mainmast, with a shorter foremast (~25–26′) stepped just forward of the coachroof, roughly 25–30% of the LWL aft of the stem.
You’d fly:
Main (Marconi)
Staysail between the two masts
Jib or yankee forward of the foremast
Sail balance ratio (approximate):
Mainmast sail area: 55–60%
Foremast sail area: 40–45%
Total sail area target: ~600–650 sq ft (same as original BCC cutter rig, so right in its power band)
PERFORMANCE COMPARISON (vs. original BCC cutter)
| Trait | BCC Cutter | BCC Staysail Schooner |
| Ease of handling | Excellent | Better — smaller individual sails |
| Balance | Mild weather helm | More neutral |
| Heaving-to | Excellent | Even better |
| Windward ability | Slightly better | Slightly lower (shorter foretriangle) |
| Offwind power | Moderate | Better — twin sails balance better |
| Aesthetic & tradition | Classic cutter | “Mini Alden schooner” charm |
| Maintenance | Simple | Slightly more rigging upkeep |
| Versatility | Good | Excellent — more combinations |
| Safety (redundancy) | Very high | Even higher (two spars, divided loads) |
DESIGN PHILOSOPHY COMPARISON
| Designer / Rigger | Reaction to this Conversion |
| Brian Toss | Would praise your triangulated, columnar load path and redundant stays. He’d emphasize spreader-root reinforcement and chainplate tie-ins to the GRP structure. |
| John Alden | Would love it. You’ve essentially recreated his 1920s 28′–32′ schooners like Malabar Jr. — same proportions, same intent, with modern safety margins. |
| Lyle Hess | Might raise an eyebrow, then grin. “A schooner’s too fancy for me — but she’ll be a dry, steady little ship.” He’d approve of the redundancy and balance if kept simple. |
Summary sentence:
A Sam L. Morse Bristol Channel Cutter refitted as a staysail schooner would combine the strength and stiffness of modern GRP with the balance, grace, and versatility of an Alden-era schooner — a rig that Brian Toss would approve mechanically, Alden would admire aesthetically, and Lyle Hess would grudgingly admit “she’ll bring you home.”
